Fusion Manufacture
Hello, I would like to ask what is the solution for what I have attached
2 REPLIES 2
xowar86003
82 Views, 2 Replies
the problem here would be that the picture does not turn it out where it should, what would be the solution
2 REPLIES 2
jhackney1972
in reply to: xowar86003
You will need to attach your model so the Forum users can troubleshoot the issue.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
seth.madore
It looks like we're looking at the spun profile of the leftover stock from prior turning operations. But, as @jhackney1972 suggests, the Fusion file would be most preferred.
Seth Madore
