New to the forum and fusion
Need some assistance on using the heights tab. I set up for drilling multiple parts in a fixture and crashed into the fixture moving to the next part after the first drilled part. My question is : After the drill cycle is completed and moves to the next part, does it rapid from the feed height or the retract height. When I Simulated the operation there was no collision in simulation assuming then it was good.
A few facts is that I set feed height .250 above hole -retract and clearance height was set above fixture.
Link copied
