- Mute
- Permalink
- Report
Hey ppl,
Im having a problem with the radius offset using the Heidenhain post from the Fusion post library. Im using a basic 2D ADAPTIVE strategy to empty a pocket using a single 10mm milling tool. The post outputs L command with X and Y coordinates during the end of the path for the spiral movements. The pocket came out a little small and I wanted to make it a little larger and whatever I did using DR or tool offset in the tool tables did not have any effect on the path. Now, I believe this is happening because fusion is using a centerline path but, is there any other way to do this or what am I doing wrong? Thanks.
Fusion
