Fusion Manufacture
Heidenhain post home mod
5 REPLIES 5
swpm4FJMQ
134 Views, 5 Replies
I would like to add a label to each program and call it before each M01 in the program. Could anyone point me in the right direction on how to do this. Have attached what I would like to achieve below, highlighted in red is what i would like to add:
 * - BORE MIDDLE
 TOOL CALL Z S4800
 M3
 L X+10 Y+0 R0 FMAX
 L Z+50 R0 FMAX
 CYCL DEF 32.0 TOLERANCE
 CYCL DEF 32.1
 CYCL DEF 208 BORE MILLING ~
Q200=+2 ;SET-UP CLEARANCE ~
Q201=-20 ;DEPTH ~
Q206=+1600 ;FEED RATE FOR PLNGNG ~
Q334=+1 ;PLUNGING DEPTH ~
Q203=+0 ;SURFACE COORDINATE ~
Q204=+20 ;2ND SET-UP CLEARANCE ~
Q335=+24.8 ;NOMINAL DIAMETER ~
Q342=+14 ;ROUGHING DIAMETER
 L FMAX M99
 L Z+50 FMAX
 M9
 * - FINISH PROFILES
 M5
 CALL LBL 88
 M1
 TOOL CALL 22 Z S5800
TOOL DEF 10
M3
M30
 LBL 88
 M25
 L X-800 Y-50 R0 FMAX M91
 LBL 0
 END PGM 8116-OP1 MM
Regards
Tom
5 REPLIES 5
swpm4FJMQ
in reply to: swpm4FJMQ
Anyone able to help?
Regards
Tom
a.laasW8M6T
Hi
I have done this post modification for our Nicolas correa with TNC426
If you upload your postprocessor here I can do the same for you, its not too hard to do but a little hard to explain haha
swpm4FJMQ
Thanks, please see attached post.
Regards
Tom
a.laasW8M6T
see attached
Look at line 1365
and line 3395
swpm4FJMQ
That's perfect, thank you very much!
