Fusion Manufacture
heidenhain post head position angles and rotary table aroud axis y
10 REPLIES 10
Message 1 of 11
gleblancE33J8
248 Views, 10 Replies
hi ,
is it possible to modify the heidenhain post to rotate the head angles simultaneously using a B axis rotary table?
thanks,
Ghys
10 REPLIES 10
Message 2 of 11
a.laasW8M6T
in reply to: gleblancE33J8
You should be able to do this no problems.
But for clarity do you have a picture of the machine and how it is configured, so we can see exactly how the head/table is in the machine
Message 3 of 11
gleblancE33J8
in reply to: a.laasW8M6T
[Image.png]
Message 4 of 11
a.laasW8M6T
Sorry there appears to be no picture there, can you try again?
Message 5 of 11
Message 6 of 11
should better with that
sorry to my mistake
Message 7 of 11
a.laasW8M6T
OK, a few more questions
Is this the correct layout for the axes?
Is the head a controlled axis? Like the C axis?
or is it a manual one?
So the Table is B rotary
and with the Head shown in the picture would you program with Tool axis Y when you do a tool call?
Like "TOOL CALL Y S3000"
Message 8 of 11
gleblancE33J8
head angles is change by the control by cyc def 302 or 320 i'm suppose is from builder Kiheung machineScreenshot 2023-02-27 194252.jpg
Message 9 of 11
and suppose the table should turn around Z axis angle C is already use in cycle 320 to align tool
Message 10 of 11
a.laasW8M6T
Ahh yes.
Unfortunately that sort of machine is a bit outside of the scope of the standard post processor.
It is possible to do, however I would suggest reaching out to one of the Postprocessing partners do work with you to make a custom post
https://customersuccess.autodesk.com/partners/search?search=Post%20Processor&locations[]=detect
I do use the standard post for our Nicolas correa mill with indexing head, but it has no rotary for simultaneous moves, and I sort of cheat by using 3D basic rotation at the control and multiple setups in fusion
Message 11 of 11
setup look like this and the result code
angle c is show in cycl 320 head orientation and should be for table
