Fusion Manufacture
Heidenhain 5 Axis M128 Change Before Positioned
3 REPLIES 3
bobbyW3KYK
126 Views, 3 Replies
There may be simple solution to this but I can't find it so far.
I have a 5 axis mill with tnc 530 control.  The tool paths work fine once positioned.  The problem is the post switches to M128 (tcpm) at the Z max (140).  The machine, depending on where it is starting from will crash or overtravel trying to get to position.  It seems it should go to the tool path clearance plane with table tilted before switching over to M128.  The 3 + 2 paths are fine just synchronous paths that this issue occurs.
I am using "use rotary angles" for the tilted work plate and not checking the TCMP.  This code loads and runs fine as stated.  It just needs to get to position before switching over to M128.
Thanks Much!
8 * - Swarf1
9 M5
10 TOOL CALL 22 Z S5000
11 L M140 MB MAX
12 M126
13 M3
14 LBL 1
15 CYCL DEF 247 DATUM SETTING ~
Q339=1 ; DATUM NUMBER
16 L A-49.259 C+138.309 R0 FMAX
17 M128                                             ////////////////////////switches to TCPM at Z max
18 L X+3.3971 Y+0.6873 R0 FMAX                   ////////////can't move to first position without crashing.
19 L Z+8.2358 R0 FMAX
20 M8
21 CYCL DEF 32.0 TOLERANCE
22 CYCL DEF 32.1
23 L X+3.3971 Y+0.6873 Z+8.2358 FMAX
24 L Z+4.0774 FMAX
3 REPLIES 3
AdamKunzo
in reply to: bobbyW3KYK
Is there any reason you are not using Plane Spatial? You can use it in combination with CYCL DEF 7 datum shift.
Try to replace lines 8-24 with following:
8 * - Swarf1
9 M5
11 L M140 MB MAX
12 M126
13 M3
14 LBL 1
16 Q339=1 ; DATUM NUMBER
17 LBL 0
18 L A-49.259 C+138.309 R0 FMAX
19 CYCL DEF 7.0 DATUM SHIFT
20 CYCL DEF 7.1 X+3.3971
21 CYCL DEF 7.2 Y+0.6873
22 CYCL DEF 7.3 Z+8.2358
23 PLANE SPATIAL SPA-49.259 SPB+0 SPC+138.30 STAY
24 L X+0 Y+0 R0 FMAX
25 L Z+0 R0 FMAX
26 CYCL DEF 7.0 DATUM SHIFT
27 CYCL DEF 7.1 X+0
28 CYCL DEF 7.2 Y+0
29 CYCL DEF 7.3 Z+0
30 PLANE RESET STAY
31 M128
32 CYCL DEF 32.0 TOLERANCE
33 CYCL DEF 32.1
34 L X+3.3971 Y+0.6873 Z+8.2358 FMAX
35 L Z+4.0774 FMAX
If this will help, you can send me message, I offer PP modifications as a service and I can sort out this for you.
I have many 5X Heidenhain fully functional post processors for differents machines.
bobbyW3KYK
in reply to: AdamKunzo
Thanks.
The machine errors out at 30 PLANE RESET STAY which is probably why I was not using the spatial plane.  Not sure how to get around that.
Good to know on the post service!
AdamKunzo
what's the error message?
