09:14 AM
I'm having trouble selecting an open contour from a sketch. I've done this exact operation many times before and I've never run into this issue. I can select the entire shape without any problems. When I try to select the shorter line and the two arcs as an open contour it will only let me select the shorter line or the arcs. I've tried redrawing the sketch and making it an open contour with the same results.
I can select the entire shape.
I can select the shorter line, but not the arcs.
Here's a link to my project.
Any suggestions would be appreciated.
Chris
