Fusion Manufacture
having issue with my Pocket NC not recognizing a line
1 REPLY 1
mickyfastiggi
89 Views, 1 Reply
(SWARF6 2)
N18280 G54 G0
N18285 G0 A24.295 B51.454
N18290 G6.2 X-0.4874 Y1.2001 Z-0.1737 I1 J1 K0 P1 F5000.
N18295 G6.2 X-0.4874 Y1.2001 Z-0.1737 I0 J0 K1 P1
N18300 M428
G6.2 is not recognize by Penta Machine software, it worked in the simulator but not the actual machining
Labels (4)
1 REPLY 1
Hi @mickyfastiggi
Apparently, the G6.2 command is used for positioning the machine when TCP is active.
I don't know if this command is part of an option pack or not.
If your machine is a 3 axis machine, you can probably replace the G6.2 by a G1 command instead, without too much problem.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
