Fusion Manufacture
Having issue running this program!!!
12 REPLIES 12
Message 1 of 13
litodrums
253 Views, 12 Replies
I'm enclosing the g code for this program that throws an alarm: Z. I'm also enclosing the F360 CAD CAM file. I hope someone can let me know what I'm doing wrong. Please note all my other .nc programs run fine. Thank you
["(Retainer Ring Cut Off 1)", "(T3 D=1.915 CR=0 - ZMIN=-1.125 - slot mill)", "G90 G94", "G17", "G20", "(When using Fusion 360 for Personal Use, the feedrate of)", "(rapid moves is reduced to match the feedrate of cutting)", "(moves, which can increase machining time. Unrestricted rapid)", "(moves are available with a Fusion 360 Subscription.)", "G28 G91 Z0", "G90", "", "(Circular1)", "T3", "S5000 M3", "G17 G90 G94", "G54", ["block", true, true, null, ["G0 X8.3738 Y0.1915", "Z0.6"]], ["block", true, true, null, ["G1 Z-0.9335 F40", "G18 G3 X8.1822 Z-1.125 I-0.1915 K0", "G1 X8.0865", "G17 G3 X7.895 Y0 I0 J-0.1915", "G2 X-7.895 Y0 I-7.895 J0", "X7.895 Y0 I7.895 J0", "G3 X8.0865 Y-0.1915 I0.1915 J0", "G1 X8.1822", "G18 G2 X8.3738 Z-0.9335 I0 K0.1915", "G1 Z0.2", "X8.155 Y0.1915", "Z-0.9335", "G3 X7.9635 Z-1.125 I-0.1915 K0", "G1 X7.8678", "G17 G3 X7.6762 Y0 I0 J-0.1915", "G2 X-7.6762 Y0 I-7.6762 J0", "X7.6762 Y0 I7.6762 J0", "G3 X7.8678 Y-0.1915 I0.1915 J0", "G1 X7.9635", "G18 G2 X8.155 Z-0.9335 I0 K0.1915", "G1 Z0.6", "G17", "G28 G91 Z0", "G90", "G28 G91 X0 Y0", "G90", "M5", "M30"]]]
12 REPLIES 12
Message 2 of 13
seth.madore
in reply to: litodrums
Is the code you posted above what you're actually sending to the machine?
Can you put the actual g-code file as well as another GOOD file into a .zip folder and attach that here?
What post processor are you using?
Seth Madore
Message 3 of 13
litodrums
in reply to: seth.madore
Yes this is the code here it is again. sorry for not having them in Zip. The first [Retainer Ring Cut Off 1"] is the problem .nc. The second works fine. Thank you very much
-EDITED BY SETH MADORE-
(removed the NC code and replaced it with .NC files)
Message 4 of 13
seth.madore
Please refrain from copy/pasting a whole shedload of nc code. The SPAM filter often picks those up and sends the entire thread to the trashcan
Seth Madore
Message 5 of 13
litodrums
my apologies ...
Message 6 of 13
seth.madore
All good, it's fixed now 🙂
Seth Madore
Message 7 of 13
litodrums
Thank you very much
Message 8 of 13
seth.madore
What's the actual alarm and when does it occur in the program; right at the onset, partway through, all the way at the end?
Seth Madore
Message 9 of 13
litodrums
I home the machine then jog the head to the work coordinates and zero in. Send home again then and hit run. The Z axis travels up to the limit switch and causes an "Alarm: 2" and "Alarm: Z" I have to stop the program and reset.
Message 10 of 13
litodrums
GRBL is what I'm using.
Message 11 of 13
seth.madore
Did this happen right after running some good code, or is this happening from a fresh boot up? Looking at the header and footer, both of them seem to be quite identical.
In this image, I've removed everything related to the actual cutting and just left the beginning and end of the program (where the issue is occurring)
Seth Madore
Message 12 of 13
litodrums
I believe I solved the issue. I opened F360 and created a drawing with a small Diameter. Then I created  g code file and ran it successfully. What I may have done originally is to try to machine an object that is too large for the specs on my machine. I have a bench top and the working area is 4"x16"x16". I may have exceeded those limits causing the Alarm Z.  Does this sound logical??
Thank you all for your input and suggestions. I have a lot respect for you guys.
Happy Holidays
Message 13 of 13
seth.madore
Yes, this is extremely possible!
Seth Madore
