have trouble with chamfer command in cam :(
johnptc314159
johnptc314159
i would like to chamfer the hole after facing the top off that was used to hold the part in the mill to work on the other side.  help :)_
model https://a360.co/3LHWnva
seth.madore
As you have it modeled, this is not possible. It's not an entirely proper workflow to create a model that reflects what you're going to (in theory) end up with at the conclusion of OP1. Rather, model the part as it should be when completely machined and then define stock accordingly.
Now, there are some cases where one would desire to create a model to represent what stock should be in subsequent operations, and that is something I do fairly often.
Seth Madore
seth.madore
I've modified your file to represent what I think you're looking for, as well as demonstrate what I'm going on about. Give it a look and let me know if you have any questions!
Seth Madore
johnptc314159
thanks 🙂
it wasnt modeled that way........ that was what was left from the operation on the flip side 🙂
got it 🙂
best
john
