Fusion Manufacture
Has Fusion turning completely shat the bed?
2 REPLIES 2
steveHDPJT
165 Views, 2 Replies
What is this doing? Doesn't respect specified inner radius. Doesn't respect specified front offset. Doesn't respect "no axial grooving". Doesn't respect "OD profiling". Doesn't respect tangential extension - it's not tangent. Should be the simplest possible turning operation one can do. Not even one element of it works properly.
Profile finishing operation for a ring:
steveHDPJT_3-1693769817025.pngsteveHDPJT_4-1693769882878.pngsteveHDPJT_5-1693769907790.png
2 REPLIES 2
If you can recalculate by closing the spun profile, the problem can be solved.
seth.madore
in reply to: steveHDPJT
And if that doesn't solve the issue, would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply.
Seth Madore
