Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
HAAS VF2 POST PROCESSOR ISSUE
1 REPLY 1
mikolaj.springer
353 Views, 1 Reply
I'm having problems with postprocessor for haas ngc machines on HAAS VF2SS+TR160d4 . I can't get good DWO orietation. When i activate A axis and C axis, post processor calculates Y position wrong. C axis schould be C0 and drill position Y-11.
N210 M1
N215 T2 M6
N220 S437 M3
N225 G54
N230 M11
N235 M13
N240 G0 A-90. C180.
N245 M10
N250 M12
N255 G254
N260 M8 P1
N265 G0 X0. Y11.
N270 G43 Z30. H2
N275 T1
N280 G0 Z20.
N285 G98 G81 X0. Y11. Z-8. R16. F65.49
N290 G80
N295 G0 Z30.
But when i turn off c axis program looks good. I tried all configurations reversed non reversed it's all the same. Can someone send me good postprocessor for this setup?
Program without C axis enabled
N200 M1
N205 T2 M6
N210 S437 M3
N215 G54
N220 M11
N225 G0 A-90.
N230 M10
N235 G254
N240 M8 P1
N245 G0 X0. Y-11.
N250 G43 Z30. H2
N255 T1
N260 G0 Z20.
N265 G98 G81 X0. Y-11. Z-8. R16. F65.49
N270 G80
N275 G0 Z30.
Tags (2)
Labels (3)
1 REPLY 1
Hi @mikolaj.springer,
So What's you machine axis limits? This problem is because of the axis limit I suspect
you can modify this section to get expected output
      if (hasA) { // A Axis - For horizontal machines and trunnions
        var dir = properties.hasAAxis == "reversed" ? -1 : 1;
        writeBlock(dir);
        if (hasC || hasB) {
          var aMin = (dir == 1) ? -120 - 0.0001 : -30 - 0.0001;
          var aMax = (dir == 1) ? 30 + 0.0001 : 120 + 0.0001;
Change the above section as mentioned below
        writeBlock(dir);
        if (hasC || hasB) {
          var aMin = (dir == -1) ? -120 - 0.0001 : -30 - 0.0001;
          var aMax = (dir == -1) ? 30 + 0.0001 : 120 + 0.0001;
reversing the limits will get you what you wanted
Boopathi Sivakumar
Senior Technology Consultant
Technology Administrators
