Fusion Manufacture
Haas TL2 Post Modifications Needed
5 REPLIES 5
jcracing135
329 Views, 5 Replies
Hi all,
I have a 2019 Haas TL2 with a manual tool post and there are are some items that are bugging me in the generic haas turning post that I'd like to see if I can get resolved.  Here's the main hit list for now:
  1. Uses interpolated X and Z values to radius a curve making it hard to adjust on the machine, how can we force the post to output an R value instead that's easily adjusted?  In some cases we want to see the R value for simple 90 degree radiused edge brakes, and other times we want to see an I/J/K value using G2/G3, but for some reason it only does point to point in X/Z moves.
  2. Outputs a G98 (feed per inch) instead of G99 (feed per rev) on drilled holes.  How can we force it to use G99 for everything, always?
  3. G53 home position on Z doesn't retract to where I want it to for my manual tool change position.  It only sticks the X value in, no Z between tool changes and I always have to go add it before the next tool change.  It does work however at the end of the program.  Is there a setting to also make this happen between tool changes since I have the Manual Tool Change option in the post selected as YES?  One would think that if that option is set to YES, move the tool post to G53 values specified in the post options.
Thanks in advance!
Tags (4)
5 REPLIES 5
seth.madore
in reply to: jcracing135
For the first one, setting this to "true" will solve the R value versus I/J/K:
 useRadius: false, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words.
I'm going to skip the second question right now, as I'm not immediately sure of the best way to do it, but I'll poke at it a bit as time allows
For the third question, change this line (around 817):
   writeRetract();
To:
writeRetract(X, Z);
This is assuming you are using this Haas Turning post found HERE
Seth Madore
Arun.rs
in reply to: seth.madore
HI @jcracing135
For the two question @seth.madore has given the correct solution.
For your second query, to change G98 to G99 for drilling cycle. I find one similar post in forum. Attaching for your kind reference : https://forums.autodesk.com/t5/fusion-360-manufacture/need-post-to-change-g98-to-g99-during-drilling...
If you got any doubts regarding editing the post please let me know.
For detail info about the post editing please refer the  FAQ link
Regards
Arun.RS
Technical Consultant - Post Processor
jcracing135
Thank you for the reply @seth.madore and @Arun.rs !
I attached the post I am using.  We have already made a few small adjustments to it.
Line 48 is now set to true but I am still not getting R values on edge breaks.
I can't find where the writeRetract is located...maybe this wasn't in the original post that I downloaded from the site back in September 2020?
I also can't find where to change the Feed per Minute to Feed per Rev.
Can you guys please have a quick look at this post and let me know if this is the same post you assumed I was using?
Thanks!
Jason
Arun.rs
HI @jcracing135
Apologies for delay in reply.
1. For R output for circular motions, you have to set 'allowedCircularPlanes = undefined;' . This is allow circular interpolation in all three planes
allowedCircularPlanes : Defines the standard planes that circular interpolation is allowed in,PLANE_XY, PLANE_YZ, PLANE_ZX. It can be set to undefined to allow circular interpolation in all three planes, 0 to disable circular
interpolation, or a bit mask of PLANE_XY, PLANE_YZ, and/or PLANE_YZ to allow only certain planes.
allowedCircularPlanes = undefined; // allow any circular motion
2. For Homing codes, the newer version of HAAS turning post has  'writeRetract()' , you can download from here
OR
You can edit in your modified post processor
a. Go to line number 785
b. Remove '//' from below codes
  //writeBlock(gFormat.format(53), gMotionModal.format(0), "Z" + zFormat.format(properties.g53HomePositionZ)); // retract
    //zOutput.reset();
3. For Feed per revolution,
  a. Go to line number 853 , and replace
From this:
 if (currentSection.feedMode == FEED_PER_REVOLUTION) {
    writeBlock(getCode("FEED_MODE_UNIT_REV"));
  } else {
    writeBlock(getCode("FEED_MODE_UNIT_MIN"));
To this :
    if (currentSection.feedMode == FEED_PER_REVOLUTION || getParameter("operation-strategy") == "drill") {
  } else {
b. Go to line number 1346 , Change
From this:
var F = cycle.feedrate;
To this :
var F = (gFeedModeModal.getCurrent() == 99 ? cycle.feedrate/spindleSpeed : cycle.feedrate);
Save the file and check the NC output carefully.
Regards
Arun.RS
jcracing135
Hi @Arun.rs
I just posted a program using a tap, (one of the firsts I believe we have done on this lathe), and the output feedrate is not correct.
The G84 code it posts is G84 X0. Z-0.8906 R-0.337 P0 F35.7143
RPM is 1000
This is for a 1/4-28 tap
Feedrate should be 1/28 = .0357 and should be independent of RPM.
I do not have an option in F360 to specify IPR, it only shows SFM.
Is there something that needs to be changed in the post or somewhere else to specify the correct feedrate in IPR?
Thank you!
Jason
