Fusion Manufacture
Haas (Pre NGC) Post process Edit - Coolant on location
3 REPLIES 3
james97MS
164 Views, 3 Replies
I am looking to move the location of my M08 coolant code within my post processor to save me manually re-typing it every time. I am looking to put the coolant on and off at my retract height. I am using the Haas (Pre NGC) post.
Can someone help?
Thanks in advance
3 REPLIES 3
seth.madore
in reply to: james97MS
It looks like it's already turning off immediately after the retract move. To have it turn on right at the first clearance move, you need to move
var coolantIsOutput = (tool.coolant != currentCoolantMode) || operationNeedsSafeStart;
  setCoolant(tool.coolant);
To line 3075, so it looks like this:
 writeBlock(gMotionModal.format(0), x, y, z);
      forceFeed();
Result:
N45 G1 X3.1496 Y-0.9596 F500.
N50 G0 G43 Z0.5906 H1
N55 T2
N60 G0 Z0.1969
N65 M8
N70 G1 Z-0.0394 F39.37
Seth Madore
james97MS
Thank you for getting back to me.
Now that I have moved that section of code, there is no longer a M09 at the return to my safe retract position once the machining has been completed. See below processed code;
N260 X165.279 Y16.829 I-23.8 J0.
N265 G1 G40 X148.45 Y21.213
N270 G0 Z100.
(ROUGH RECESS)
N275 M1
N280 T2 M6
N285 S1800 M3
What I am also after is for after line N270 Z100. I would like here to be as follows;
N275 M09
N280 G53 Z0
N285 M1
Then the next tool change.
Hopefully this makes sense.
Can you please point me in the correct direction?
Thanks again
I posted about this before
https://forums.autodesk.com/t5/fusion-360-manufacture/changing-coolant-start-position/m-p/11677522#M...
Please click "Accept Solution" if what I wrote solved your issue!
