Fusion Manufacture
Haas Pre NGC post modification
6 REPLIES 6
m_lamarca
169 Views, 6 Replies
We have a couple Fanuc based vertical mills, but the Haas Pre NGC seems to be the best output for our machines, minus one issue. We need an M29 line for rigid tapping. I can’t seem to find an easy way (read as check box) to add that. We have support thru a AutoDesk reseller, but that is like jumping through hoops to get done.
Is there a simple way to do this, instead of manually?
6 REPLIES 6
a.laasW8M6T
in reply to: m_lamarca
Can you provide and example of the correct code you would like?
(Tap)
N25 T4 M6
N30 S1000 M3
N35 G54
N40 G17 G90
N45 M8
N50 G1 X25. Y10. F5000.
N55 G0 G43 Z15. H4
N60 G0 Z5.
N65 M29
N70 G98 G84 X25. Y10. Z-16. R4. F800.
N75 G80
N80 G0 Z15.
N85 M5
N90 M9
N95 G53 G0 Z0.
N100 X0.
N105 G53 G0 Y0.
N110 M30
Is the above example correct with the M29 just before the tapping cycle.
does there need to be a Mcode to cancel rigid tapping afterward?
m_lamarca
in reply to: a.laasW8M6T
M29 with spindle speed. That was the only hand modification done to this program, that I am currently running.
a.laasW8M6T
Ok try this one
m_lamarca
Thanks.
i will check it out in the morning, and try to do a file compare, so I can learn what you did.
m_lamarca
Not working for me. I must be doing something wrong, I guess.
a.laasW8M6T
Sorry I realised that I only added to the "Tapping" case and not all the other ones
You may have had one of these selected.
try this
