Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
groove milling
4 REPLIES 4
1146 Views, 4 Replies
groove milling
I have a question :
Whether it is possible to define a groove milling with using trochoidal path ?
It means whether it is possible made groove exp. 8 mm width using the 4 mm diameter cutter only in one pass ?
I was waiting for this option in new CreO 3.0, but , I think , they forget.
Ludwika
4 REPLIES 4
rishivadher
Hi
It would be nice to put this in idea station for feature request
fonsecr
in reply to: rishivadher
You can use Adaptive Clearing for this. Adaptive Clearing will actually maintain the tool engagement angle for the cutter which is better than using a fixed toroidal curve. For a narrow slot the motion will look quite similar to a toroid but as the width is increased the difference will be more clear.
http://camforum.autodesk.com
René Fonseca
Software Architect
fonsecr
in reply to: fonsecr
Should have said "trochoid" instead of "toroid" 🙂
René Fonseca
Software Architect
Many thanks for your response. I will try to use Adaptive Clearing. CAM module in ADF 360 is  new for me. I am still "green" in it.
