Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Groove machining on Hwacheon Fanuc lathe without Y axis
4 REPLIES 4
Matt_Leon
263 Views, 4 Replies
I have to work a groove as shown in the image. The lathe is a Hwacheon - Hi-tech 700 MC without the Y axis .
The machining is currently performed with the combination of X axis and rotary C but the slot is not very good.
How can I correctly make the path with Fusion and export the program  correctly?
thanks
this is the sharing link
https://a360.co/3CRYwBN
Labels (4)
4 REPLIES 4
a.laasW8M6T
in reply to: Matt_Leon
Unfortunately you cannot machine that feature completely without a Y-axis
The best you will get is to go on center with a 20mm endmill using 2D contour picking one edge and using tangential extension to move the start point(also turn off leads).
This will not machine the "Wings" of the start of the slot.
For the other keyways you can use the slot tool path to ramp down.
see attached
Matt_Leon
in reply to: a.laasW8M6T
now the machine operator has programmed the machining by combining the movements between the X axis and the C spindle, is it possible to replicate this type of movement with Fusion?
thanks!
a.laasW8M6T
Yes it is possible to sort of get this motion.
You can use the Wrap toolpath feature on 2D contour but it will never machine the feature even close to correct
Another option could be the Rotary toolpath. this seems to give a better approximation:
I assume the operator is using G112 at the control, this will still only ever give an approximation of the feature as you cannot generate parallel walls/ flat floors by rotating the C axis
The Wrap function in 2d contour is basically the same as the G112
Matt_Leon
thanks @a.laasW8M6T !!!
Technology Administrators
