Fusion Manufacture
Graphics Tearing During Simulation - No accurate model to refernce?
2 REPLIES 2
CNCWoodarts
93 Views, 2 Replies
How do I fix this?
This doesn't happen often but it has happened before. The graphics are not rendering correctly, this is often called "tearing" I have an RTX1650Ti GPU on an XPS15 Laptop. Its a 2-sided operation, the 1 side simulates ok, the second side does not.
2 REPLIES 2
seth.madore
in reply to: CNCWoodarts
Hmm, I've not seen something like that in a while, but it's obviously still a problem with some platforms.
I'm assuming you've updated all your graphics drivers?
What does your Graphics Diagnostics tell us? It's found here:
Seth Madore
brekmiller
That looks like CAM-39204, which has already been fixed.  You will get the fix in an upcoming release.
CAM-39204 affects only the "Comparison" colorization.  I think you can avoid the problem by choosing a different colorization mode.
Brek Miller
Software Engineer
