Generic Pro Light Lathe Post in Fusion 360
kwertmanX3F6N
kwertmanX3F6N
I am in need of assistance in adding the post for a generic pro light cnc lathe. I am using fusion 360 and am not sure how to add the post.
I think I may have it loaded since it does say pro light .cps in the post configuration tab but when it goes to generate the code it doesn't actually produce any G code. It only gives me this list of errors. Any idea what could be the problem? These errors don't make any sense to me. The machine is new to me and is in a school. I have very little knowledge about the machine and am just getting started in CNC and fusion 360.
Information: Configuration: Generic proLIGHT Turning
Information: Vendor: Light Machines
Information: Posting intermediate data to 'C:\Users\owner\Desktop\1001.nc'
Error: Failed to post process. See below for details.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Friday, December 09, 2016 5:08:23 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41239
Configuration path: C:\Users\owner\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts\proLIGHT turning.cps
Include paths: C:\Users\owner\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts
Configuration modification date: Thursday, December 08, 2016 1:15:06 PM
Output path: C:\Users\owner\Desktop\1001.nc
Checksum of intermediate NC data: f13b9dc848bc724a6478137bd4d2e8c3
Checksum of configuration: cbbb4abeeec7121334df68e3313cbdb3
Vendor url: http://www.autodesk.com
Legal: Copyright (C) 2012-2013 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.2535
Error: Feed per revolution is not supported by the CNC.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Friday, December 09, 2016 5:08:23 PM
Post processing failed.
LibertyMachine
The reason it's not working is stated in the error:
Feed per rev is not supported. Turn off "Use Feed per Revolution" and try it again 😉
I'd be remiss if I didn't ask one important question not related to this error: Which folder did you place the post processor in? If you dumped it in the Generic Post folder...You're gonna be in for a rough time at the next software update. Every update, the generic folder gets wiped and replaced. You're better off putting it on the Cloud or a personal folder of your choice and directing Fusion to search that location.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
