Generating 2D Contour from 2D mesh
BoehmeLVA4Z
BoehmeLVA4Z
We are thinking about adding CLO 3D Fashion to our design workflow. A design shall be created in CLO and then transferred to Fusion 360 to apply minor changes and create the G-code. Formats that work in both programs are .fbx, .dxf, and .obj. Importing .dxf does not work, both the normal way over upload and over DXF Importer Add-in. CLO exports in DXF-AAMA and DXF-ASTM. The other two formats .fbx and .obj result in mesh bodies (in our case 2D).
We would like to generate a 2D tool path for a cutting process that is supposed to go around the edges of the body. Unfortunately, the mesh cannot be selected in the 2D profile menu. Generating a sketch via Mesh Section Sketch does not work because it is a 2D mesh. The only workaround that kind of worked was converting the mesh into bodies and then using the projection in the sketch menu. In that way, we ended up with a very coarse sketch with no round edges. Does anybody have experience in working with both programs CLO and Fusion together or can give a tip regarding importing the attached DXF file? I always get a failed message but no error code or any other kind of information. I attached the fbx format as well, in case somebody has a suggestion regarding using meshes as the base for 2D contours. Thank you so much in advance.
Best regards,
Florian
engineguy
@BoehmeLVA4Z
This looks like one for the Developers, I can`t open the dxf in Fusion either but was able to open in another Cad-CAM software I have and re-save from there and then was able to open in Fusion, the Fusion f3d file I saved out of the Sketch is attached if it is of any help to you 🙂
BoehmeLVA4Z
Hi @engineguy,
Thank you so much for your effort. It is good to know that other CAD programs can apparently open the DXF because we are also in contact with the CLO support, but then it looks like it is something in Fusion causing the trouble.
Maybe one of the developers knows a solution.
Best regards,
Florian
BoehmeLVA4Z
Hey,
are there other people, preferably developers who have experience with that or any tips?
Best regards,
Florian
