Fusion Manufacture
generate bore tool path fails to find circular faces
6 REPLIES 6
djlunty
180 Views, 6 Replies
When re-generating a previously generated bore tool path it fails to find circular faces that are circular.  They are circular - generated yesterday and have a radius and diameter when using inspect.
Before Generate
After Generate
With the following warning
All I did was Generate the tool path
The components are were created from a sketch with two circles and an extrude so no funky splines
Undo gets the tool path back.  Same problem for all the setups in this file.
If I copy the component  (display wheel spacers)
to a new file
I can generate a new tool path
If I recreate the hole in the component in the original file (delete inner circle, redraw and extrude) still get the error when trying to edit the tool path.  Deleting the tool path and creating it again still gives the error.  Changing cutter size from 1/4 to 3/16 makes no difference,  Restarting Fusion makes no difference.
Seems to be something with the  bore tool path in this particular file but I cannot find what I may have changed.
The original file and the test file attached.
Doug
Doug
6 REPLIES 6
djlunty
in reply to: djlunty
Checked file again today and finding circular faces was erratic - would find them about 1/3 of the time.  Also could not find circular faces for Circular Toolpath.  Seems to have a mind of it's own and just tormenting me.
Tried to repair fusion using the service utility - could not find some file so just uninstalled fusion and re-installed (third time in last two days) and now it works - can find circular faces with the bore tool path
Hope it keeps working!!!
Doug
seth.madore
This does seem quite odd. If I create a Setup off the Design Model (not the MFG model) I'm able to create a toolpath with Bore:
More investigation is required... 
Seth Madore
seth.madore
I've opened CAM-50149 to investigate this issue.
Seth Madore
djlunty
in reply to: seth.madore
@seth.madore
Had the same problem today - would not find circular faces with bore tool path.  Attached is a file with a bore tool  path that works - and a bore tool path that will not find circular faces.
A way I got it to work was when no circular faces are found say "No" to the error message (do not complete the tool path) You will be taken back to the bore tool path dialogue box and now the bore faces can be selected as circular faces - weird!
If one circular face is found  but not a second one  say "OK" in the dialogue  box (complete generating the tool path) and then go back and edit the tool path and select the missing faces and and now they will be selected as circular faces - weird again.
Being as the behaviour is  erratic  I am not sure if the above methods work all the time.
The attached file is part of the original file I sent - just copied and pasted a couple of components into a new file.  Don't know if that would make any difference.
Doug
seth.madore
Interesting workaround, but I'm not given a message that presents anything other than "OK":
Seth Madore
djlunty
@seth.madore
This morning I do not get the error "Unable to find circular faces".  Instead I get the same error as you "Failed to generate tool path".  I wonder if it has something specific to do with my install of fusion.  In the last few days when if I use the  service utility to Repair Fusion it fails and I have to do an uninstall and reinstall.  Maybe I have to try a Clean Uninstall- up to now I have been doing the  uninstall from Widows Control Panel.  Your thoughts?
Doug
