Announcements
Gang tooling setup sheet only shows one tool
sashaveselov
sashaveselov
Hello all, i have looked and couldnt find exactly what i was looking for. I think someone is a fusion users group on facebook said its not possible so i just wanted to double check here. My issue is when i post a setup sheet for a lathe that has gang tooling (one tool number, different numbered offsets) the setup sheet only includes the first tool in the gang. i understand why this is the way it is, but is there any info on what, if anything, i can modify to make it give me every tool/ offset even though the tool number is the same, just the offsets are different? like can you tell it somewhere to consider different unique offsets as the unique tools? sorry if this doesnt make sense, was trying to be as discriptive as possible.
Replies (26)
sashaveselov
Oh ok, so at this time there isnt a solution for gang tooling Setup sheets basically?
seth.madore
Until I hear back from the post developer about the Excel ticket I opened, no. The next update will address the .fssd setup sheet (method#1)
Seth Madore
sashaveselov
OK sounds good! thank you for all your help and your time!
seth.madore
You're welcome, and I'll let you know as soon as I know about the Excel post
Seth Madore
seth.madore
We do have this fixed internally, we will update our posts in the next update (posts are updated at a separate cadence to Fusion releases) which shouldn't be "too" far away.
Seth Madore
sashaveselov
Oh ok awesome! looking forward to it thank you!
sashaveselov
Hey, so its been a while. So i noticed now sometimes two tools with the same tool number but different offsets show up, and sometime they dont on the toollist. It seems to be that my "mill" tools in the setup sheets show up with different offsets, but lathe tools dont.
Type a product name
