Fusion Manufacture
G68.2 with 4-axis CNC
2 REPLIES 2
hennebelle.benoit
1111 Views, 2 Replies
I m a beginner with fusion and CNC programming so I am still learning.
My virtual machine is a 3 axis CNC equipped with a rotary table along the X-axis.
I have a trouble with G68.2 function.
At the beginning, the table is at rest (0 degree). The Z-axis is vertical:
I want to machine the front surface so I modified the WCS for this operation to rotate the coodinated system of 90 degrees .  Z-axis is now horizontal in fusion so ready to machine the surface.
My problem is from the post processor. I think the result is an error:
G68.2 X0. Y0. Z0. I180. J90. K180.
I just have a rotation of 90 degrees around the X-axis  so I expected :
G68.2 X0. Y0. Z0. I90. J0. K0.
Why do I have this difference ? Maybe I have misunderstood the functionnality?
I have tried multiple configuration to understand the problem without success.
Thank you for your help.
BR,
Tags (2)
Labels (2)
2 REPLIES 2
Hi@hennebelle.benoit
The G68.2 Tilted Work Plane function allows user to define the Work Plane by Euler Angles for 3+2 mainly not ment for 4 Axis.
For 4 Axis we have different post in the library you can check this out
https://cam.autodesk.com/hsmposts?p=fanuc_with_a-axis
Boopathi Sivakumar
Senior Technology Consultant
OK, thread necromancy here.
I have the same issue on a Doosan where I am getting errors using G68.2 with only a 4th axis.  While I understand that it's "not meant" but I was told (by Doosan) that's its possible to use it.
My issue is I keep getting parameter errors when trying to execute it.
