Fusion Manufacture
G68.2 Post with Roll, Pitch, Yaw
9 REPLIES 9
Message 1 of 10
amir.mettawa
1582 Views, 9 Replies
Looking for any generic post that uses G68.2 P1 (roll, pitch, yaw) instead of Euler. The default Fanuc post uses Euler and I would like to build my own. The machine is a 4+1 A/C (table-table) setup.
9 REPLIES 9
Message 2 of 10
KrupalVala
in reply to: amir.mettawa
Hi @amir.mettawa,
The G68.2 P1  follows the Roll-Pitch-Yaw Euler Convention.
Open your post processor in editor or VS code and P1 in workplane definition as shown below,
writeBlock(gRotationModal.format(68.2), "P1 "+ "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0), "Z" + xyzFormat.format(0), "I" + abcFormat.format(abc.x), "J" + abcFormat.format(abc.y), "K" + abcFormat.format(abc.z)); // set frame
Now search for following variable and change it from this..
var euler = _section.workPlane.getEuler2(EULER_ZXZ_R);
to this
var euler = _section.workPlane.getEuler2(EULER_XYZ_R);
Save the post modification and test the code.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
Message 3 of 10
amir.mettawa
Thank you, that works.
There are a few instances where the 68.2 outputs do not match what they need to be. Usually when there is a combination of A and C.
For example, it should be:
G68.2 P1 X0. Y0. Z0. I-90. J0. K-180.
G53.1
However, it posts:
G68.2 P1 X0. Y0. Z0. I90. J0. K-180.
G53.1
I tried changing the preference to -1 (negative angles) but that didn't change anything.
var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120, 40], preference:-1});
I would like it to default to A movements in the (-) direction
In the case of just A axis commands, it posts this which is correct:
G68.2 P1 X0. Y0. Z0. I-90. J0. K0.
G53.1
Message 4 of 10
amir.mettawa
in reply to: KrupalVala
G53.1
However, it posts:
G53.1
G53.1
Message 5 of 10
KrupalVala
Hi @amir.mettawa ,
Could please test the code in your machine? We will get to know whether the axis of rotation is working as expected or not.
Krupal Vala
Message 6 of 10
amir.mettawa
Yes, I tested it with that code.
This is what it needs to be:
G53.1
However, this is what it posts:
G53.1
Message 7 of 10
KrupalVala
Hi @amir.mettawa ,
Could you please try using EULER_XYZ_S, The S stands for static which is roll, pitch, yaw.
Here is a picture that shows how G68.2 P1 rotates on a Fanuc control.
You will notice that the rotations are preformed in the original coordinate system (pitch, roll, yaw) in contrast to the standard G68.2 command, which rotates around Z (original system), X'(X-axis after Z rotation), Z" (Z-axis after ZX rotations).The Q123 indicates the order in which the rotary axes are rotated.
Please make sure the order of rotations is correct.
For example, let's assume we have a C/A Head/Head 5-Axis machine. The secondary axis is also sometimes referred to as the 'Slave' axis in that its position is dependent upon where the C-Axis is currently located. For this configuration, we must define the order of axis rotation as Q312. The C-Axis is the primary axis and will rotate first, The A-Axis is secondary and will rotate second.
Krupal Vala
Message 8 of 10
ifuASTJY
I am trying to setup a swivel head B axis,
Why is there no positions for XYZ? I would like to aproach the part as it tilts the work plane.
For example:
G53.1
Message 9 of 10
KrupalVala
in reply to: ifuASTJY
Hi @ifuASTJY ,
You can change this behavior and output the origin values in the G68.2 block by making the following changes to the post.  Add the mapWorkOrigin = false; as shown below,
allowHelicalMoves = true;
allowedCircularPlanes = undefined; // allow any circular motion
highFeedrate = (unit == IN) ? 500 : 5000;
Now make the following change in the setWorkPlane function.
writeBlock(gFormat.format(68.2), "X" + xyzFormat.format(currentSection.workOrigin.x), "Y" + xyzFormat.format(currentSection.workOrigin.y), "Z" + xyzFormat.format(currentSection.workOrigin.z), "I" + abcFormat.format(abc.x), "J" + abcFormat.format(abc.y), "K" + abcFormat.format(abc.z)); // set frame
You will notice that the output coordinates are changed(local workplane) to match the new origin.
Krupal Vala
Message 10 of 10
zns1258866193
This is very useful, when I added this, G68.2 outputs the correct XYZ values instead of always X0.Y0.Z0., thanks a lot!
