Fusion Manufacture
G68.2 B axis rotation incorrect.
7 REPLIES 7
Message 1 of 8
milling1UELAX
404 Views, 7 Replies
Hello, I'm having an issue machining a 25 degree inclined wall. We're using a Mazak VTC800/30SR. The B axis should rotate to (negative)-25 degrees however it rotates to (positive) +25 degrees and travels from one side of the machine to the other. The CAM side of things is good, however the EULER angles calculated by the post are complete nonsense. I've had this issue in the past and just decide to surface machine the feature however I'm sick and tired of doing it that way. Please fix the post.
Tags (3)
Labels (3)
7 REPLIES 7
Message 2 of 8
a.laasW8M6T
in reply to: milling1UELAX
Can you share an example file?
which post processor are you using?, is it just the "Mazak" one.
also do you use the machine simulation model in fusion?
Mazaks are pretty notorious for having to set certain parameters correctly to get 5 axis stuff correct
Message 3 of 8
milling1UELAX
in reply to: a.laasW8M6T
It's the Mazak VTC800/30SR machine model and MAZAK Post Processor provided by AUTODESK themselves. The post is literally moving the opposite direction from what is required. instead of a B-25 movement it's a B25. movement.
Message 4 of 8
a.laasW8M6T
So the post is configured correctly for G68.2(P0) which is an ZXZ R transformation
If i make a test part and post the code I get
(FACE1)
N25 T4 M6
N30 S6000 M3
N35 G54
N40 G68.2 X0. Y0. Z0. I-90. J25. K90.
Which appears to be correct(its effectively B-25 on the physical axis)
is that the output you are getting?
Message 5 of 8
milling1UELAX
Sorry for the delayed reply. And yes that is the line posted by the Post Processor, however the angle is the wrong direction. If it is a parameter that needs changed do you know which?
Message 6 of 8
a.laasW8M6T
That would have to be a question for your Mazak applications engineer.
as far as I can tell the post is outputting the correct Euler angles, but I could be wrong.
Maybe some of the autodesk post guys can help out ?
@serge.quiblier @boopathi.sivakumar
Message 7 of 8
Hi @milling1UELAX
On some machine, we sometimes need to eventually add a G53.1 command with an additional parameter.
I have a post for another software (PowerMill, not Fusion360) using the G53.1 for positive B values, and G53.1 P2 for negative B values.
I found a reference in a Mazak manual, but not for the VTC machine.
As you can read, this may be machine dependant:
In the post v45821 in our library, this functionnality is implemented.
Do you have a parameter on the G53.1 line? P1 or P2?
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
Message 8 of 8
ltucker_
Did you ever sort the Opposite direction B axis compared to what actually is required?
