Fusion Manufacture
G54 G55 G56 G57 NC code for sorting by tool
4 REPLIES 4
loveluckey
224 Views, 4 Replies
G54 G55 G56 G57 If post is output by sorting by tool during continuous machining, when passing from G54 to G55 in NC code, (G91 G28 Z0. M19)
The code is being called and meaningless time is being generated in the air.
can you edit this part?
4 REPLIES 4
seth.madore
in reply to: loveluckey
What post processor are you using?
Seth Madore
loveluckey
in reply to: seth.madore
I solved it myself.
thanks!
seth.madore
Okay, what were the steps you took to solve this, so other folks who run into this have some idea of what to do?
Seth Madore
loveluckey
I'm using a fanuc system and I solved this problem by doing a direct edit in POST.
The added part is the following syntax, and the corresponding data is attached as a file.
function onSection() <- Edit in function
    retracted = true;
    if(insertToolCall)
      onCommand(COMMAND_COOLANT_OFF);
      // retract to safe plane
      writeBlock(gAbsIncModal.format(91),gFormat.format(properties.useg30out ? 30 : 28),  "Z" + xyzFormat.format(0),mFormat.format(19)); // retract
      forceXYZ();
    if ((insertToolCall && !isFirstSection()) || forceSmoothing)
      disableLengthCompensation();
      setSmoothing(false);
