it use to give you the option of g28 safety retracts and I would always click No. now it doesn’t give you the option and it sure what to select. It gives you
G28
G53
clearence height
im thinking clearance height but not sure. Any help would be great.
thanks
Hi @Anonymous
Before we use two methods for retracting G53 and G28 .
If you set Use G28 as No then the older post will use G53 method
Now we have added a one more option to use the clearance plane instead of moving the Z to home after every toolpath it uses the clearance plane distance to move. it save some cycle time. if you lots of retraction
You have to use G53 if you want to match the codes when you set use G28 as NO.
@Anonymous
It looks as though it is now giving you the option of G28 or G53 so you have to have one or the other, both move the machine to Machine Home, some machine controls no longer use the older G28 so that will be why the G53 option is there.
What PP are you using, if you upload it someone will be able to either show you how to enable/disable these options or maybe even do it for you 🙂 🙂
@boopathi.sivakumar answer above does it for you, he types faster than me 🙂 🙂 🙂
Regards
Rob
This looks like what I will need, will give it a try, we have been using a Fadal post that we modified ourselves to return the table forward after cutting and removing the ( ) in the post, we did this maybe 5-6 months ago so we are using the one right before that update. Thanks for the help, if I have issues with it ill bring it in here.
