G-code to geometry, is backwards possible?
trevorJ23GY
trevorJ23GY
Hello all,
  Just getting started on Fusion 360 and one of the first questions on my mind is: Is it possible to take a proven g code program and work backwards to a drawing? Even to extract toolpaths and generate geometry. Your thoughts?
Thanks in advance.
Steinwerks
Not in Fusion. Your best bet is a backplotter with simulation capabilities (like Cimco Editor).
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
If you have access to Solidworks, You can download the wonderful and great version of HSM works 2.5 D for free. It includes the Cimco editor for free, but is totally worth paying for the full version. And that can allow you to turn toolpaths(from an existing .nc,.ncf or .txt to a .dxf  . As a bonus for you can set that Cimco to be your default editor for fusion, and it rocks.  It has really helped me migrate more of my workflow from Solidworks and Gibbs to Fusion 360. Downside is you have to have access  to solidworks and open HSM every two weeks for it to work. If It is a one time file? send me a message and Ill see if I can whip it out for you. No charge. [email protected]
Tom
HughesTooling
There's a free editor NC-Corrector that has the option to export as DXF.
Mark
Mark Hughes
Owner, Hughes Tooling
trevorJ23GY
Thank you to all for the quality responses. I look forward to trying this out.
matthew.nichols
@HughesTooling -
That NC corrector looks cool! How did you find that?
Matthew Nichols
Adoption Specialist - MFG
HughesTooling
@matthew.nichols I found it in CNCZone a few years ago.
http://www.cnczone.com/forums/coding/118442-nc-corrector-new-free-g-code-editor.html
It's pretty good, it even does 4 axis wire backplots.
Mark
Mark Hughes
