G code output
G code output
How to get the G code from apt source file.. generated tool path from other software... taken the apt  output from the software.
seth.madore
A little bit more info is needed. What post processor are you using? What is your machine and control?
Seth Madore
generated tool path from catia v5.. apt source file taken from icam mm pptable. with that file, have to take g code file from fusion 360. is it possible.? machine name : takumi post processor: fanuc Oi-mc with external attachment of 'A'-axis
seth.madore
We have a Fanuc post processor configured for an A axis machine. It will output code with a .nc format, but that can be changed to suit your needs if you need a different extension. https://cam.autodesk.com/hsmposts?p=fanuc_with_a-axis
Seth Madore
