Fusion360 - 3axis with rotary post-processor for (Finetech) machine
asdk.my2020
asdk.my2020
Do you have a working post-processor for machine mentioned below.
(Finetech) machine model :
Machine spec : A-360 / 360
Head rotate vector : A axis rotate with X
Sample NC program as below :
O1000
N1(T1 D=8. CR=0. - FLAT END MILL)
T01 M06
M01
G90 G00 G54
G90 G00 A0.
G90 G00 X0. Y0.
G43 G00 Z100. H01 S6000 M03
G00 Z10.
G01 X-1500. A-360. F1500.
G01 X0. A360.
M05
M09
G91 G28 Z0.
M30
serge.quiblier
Hello @asdk.my2020
Usin the genic Fanuc post, and applying the Autodesk Generic 4-axis (A Table) machine confiuration in the setup is your solution.
The machine configuration is defining the kinematic (A axis on the table)
And the post is grabing this kinematic, pushed by Fusion, for generating the gcode.
Regards.
PS : You just need to check, and eventually deactivate TCP on the rotary axis.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
asdk.my2020
Thanks for speedy respond I will give this a go and revert to you if needed further assistance. Cheers
