Fusion Manufacture
Fusion's been generating toolpaths with a lot more points than normal recently
10 REPLIES 10
Message 1 of 11
FrodoLoggins
227 Views, 10 Replies
Here's a 2d contour along a corner radius on a part completely made in Fusion:
Bunch of points.
Previously with that amount of smoothing one would normally only be able to see 2 like so:
I also noticed an issue with a 2d contour that had only one pass. I had finish smoothing enabled but not the smoothing tolerance lower down in the Passes tab. But smoothing would only actually be applied if I had enabled both smoothing settings.
Previously I could leave the lower smoothing tolerance disabled. Just enabling the topmost finish smoothing setting would smooth the contour's single finishing pass previously.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
10 REPLIES 10
Message 2 of 11
DarthBane55
in reply to: FrodoLoggins
So this radius... is actually a spline?  cause if it's a true radius (measure the actual curve and see if it reports a radius size) smoothing has zero effect, a radius is a radius, it output it with a G02 or G03 in 1 line as a radius (with 2d contour).  I'm curious to see if this is an actual radius or not.
Message 3 of 11
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
Message 4 of 11
FrodoLoggins
in reply to: seth.madore
File attached.
Radius highlighted in blue created with the fillet tool:
Afterwards I added this chamfer with the chamfer tool:
Then moved the faces highlighted in blue below a few thou in the direction shown with the move/copy tool:
Message 5 of 11
If you select the edge it does not show as a fillet. Not sure why but Fusion doesn't seem to create a cone on the corner.
If you use a 0.074 chamfer so there's still a small radius at the point of the cone it will work without smoothing enabled.
This is more a bug in the modeling workspace than a CAM bug. Although you'd think you could smooth to an arc. Normally you can smooth external splines if you use a very tight tolerance and a bigger smoothing tolerance but I couldn't get that to work here..
Mark Hughes
Owner, Hughes Tooling
Message 6 of 11
Hmm. The face and top edge come up as a radius:
Screenshot 2023-12-15 at 10.06.14 AM.pngScreenshot 2023-12-15 at 10.07.09 AM.png
But the top edge also gives a length value.
If anyone wants to move this to another forum section feel free.
Message 7 of 11
seth.madore
It would have been helpful to have a timeline enabled so we could retrace your steps...
Seth Madore
Message 8 of 11
HughesTooling
@seth.madore If you enable the timeline you can use the simplify tools to delete the straight sides of the chamfer. If you then recreate the chamfer with a 0.0749 size you get an arc for the edge but as soon as you go to .075 it becomes a spline. I guess Fusion doesn't like the singularity generated when the chamfer matches the corner fillet. Although the modeling kernel should probably treat this as a special case and create a cone.
Mark
Mark Hughes
Message 9 of 11
That file hurt my head. I should not of opened that up on a Friday afternoon. WOAH.
Message 10 of 11
Why's that?
Message 11 of 11
There's a lot going on in this one file. I usually separate things with multiple files so I can concentrate on one thing at a time. Your labeling system isn't that easy to follow too, which is fine if you're the only person using the file. Hats off too you if you're able to keep track of everything you've got going on in this one file though.
