Fusion Manufacture
Fusion 360 Toolpath not covering entire stock
2 REPLIES 2
kacper.kob02
96 Views, 2 Replies
Greetings,
As shown, after applying face operation it's toolpath won't cover entire stock:
This is the result after I run the simulation:
Tags (2)
2 REPLIES 2
seth.madore
in reply to: kacper.kob02
It's going to depend on some factors;
What are you using for the Stock Contour?
What have you defined for Pass Extension?
Have you specified any Stock Offset value?
Lastly, would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
That blue circle is your toolholder, not the flutes.
Please click "Accept Solution" if what I wrote solved your issue!
