Fusion Manufacture
Fusion 360 No longer Creating Command to Measure Bit Length at Tool Change
1 REPLY 1
kaleb54cookL6VEZ
70 Views, 1 Reply
Like the title says, for some reason fusion 360 is no longer measuring tool length offset after tool change. Tool changes used to be a breeze with my Shapeoko Pro. It seems as if the processor or fusion 360 has changed something removing the prompt to set an offset on tool change... Any help here would be appreciated.
1 REPLY 1
Which post processor are you using, exactly? Do you have a sample file you could share that would be used to create the g-code you expect to see?
Seth Madore
