fusion 360 and how it post
In drawing (xy origin 1) is a part that I have designed and is placed on the mill where the coordinate are positioned on the top right of the mill.  Then I zero the x y coordinates as G0 X0 is the top right as is G0 Y0 (on their respective edges).  When I post the code to the jump drive it post as all positive xy  coordinates pic (as posted in fusion).  However, to get it to run I have to change the positive xy coordinates to negative.
Why is fusion posting (better question is how am I screwing this up) in a positive numbers when no part being cut is in any xy positive path.
xander.luciano
Hello!
You're looking at the part "backwards" inside Fusion 360 :winking_face:
The arrows point in the positive direction, so what you're looking at is this:
w1yOWH5
But what you really want is this:
lC00WYL
See how the the part now lies in quadrant 3 if you were to look at it like a graph, meaning all operations will be negative X and Y values. I made a crude graph to help you visualize what I mean:
pqg0Mua
Give that a shot and let me know if you have more questions!
Best!
Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
I'm working on calibrating my eyeballs now. Thank you so much.
Herschell
xander.luciano
Haha, no problem, I'm happy to help. :slightly_smiling_face:
Xander Luciano
