Fusion Manufacture
Funky 2D Contour behavior after copying from previous setup
1 REPLY 1
FrodoLoggins
112 Views, 1 Reply
Ok so I have this 2D Contour in my first setup to cleanup the corners from a previous finishing pass:
After copying that operation to the next setup (part gets flipped) the toolpaths should look exactly the same (only without as many stepdowns as I only need 2 stepdowns to finish what's leftover from the first setup). However, the toolpath does not make a 90* angle as expected, they're just straight lines:
Now changing the contour selection's extension types from Distance to To Boundary does produce a favorable result in those corners, it also creates some extra toolpaths that don't actually mill anything:
Screenshot 2023-02-27 at 8.28.01 AM.pngScreenshot 2023-02-27 at 8.37.36 AM.png
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
1 REPLY 1
jaredSADUH
in reply to: FrodoLoggins
Hi.  I took a look at your file and the tool path in question.  What I found was to change your extension from "to boundary" to "distance".  I gave it an extension distance of .1 and got this result:
Hope that helps
