Fusion Manufacture
from powermill to fusion
1 REPLY 1
Bnuno608
100 Views, 1 Reply
hi, so im currently using powermill in my company
im running some tests in fusion but for now i would like to import some things such as:
- import toolbase from powermill to fusion( how can i do it?)
- using the pos processor from powermill to fusion, for example HEideain is missing some "M" funcionts, our maching needs "M114" to activate axis compensation, "M10" to clamp axis
where can i edit pos processor? can i run the same pos processor i use in powermill?
- machine, i have MTD files, to import machine to fusion should i have mtd files in other extension? like stl?
  • thanks in advance
1 REPLY 1
AdamKunzo
in reply to: Bnuno608
I don't think you can import anything from PowerMill to Fusion 360.
There are Fusion tool libraries available on the Autodesk Websites https://cam.autodesk.com/hsmtools
And post processor as well https://cam.autodesk.com/hsmposts
Post processor can be modified in Visual Studio Code, but I recommend having someone experienced make the modifications. I offer post processor modifications as a service and can make the post processor to generate the same NC code as the PowerMill.
Send me a message if you would like to get a help.
