Fusion Manufacture
free boundary
5 REPLIES 5
Bnuno608
147 Views, 5 Replies
free boundary
in manifacture especialy in 5 axis.
 i need to create a boundary, free hand curve.
in powermill i create workplane aligh with view and then create a basic curve by hand and do paralell toolpath(example)
in fusion, how do i create workplane aligned with my view and then sketch the boundary? so i can use it in toolpath
5 REPLIES 5
seth.madore
in reply to: Bnuno608
This is something we're actively working on developing, but it's still a longs way off. At present, you need to know beforehand what your orientation is going to be and create something in the Design space for reuse later in the MFG space
Seth Madore
jonP7QA7
in reply to: seth.madore
I'm having the same issue. I can do this if I shut the model off so it doesn't snap to it. but then I can't see where it's going.is there a way to have sketch lines not snap to the model?
seth.madore
in reply to: jonP7QA7
Could you provide some screenshots or a video of what you're running into and would like to avoid?
Seth Madore
jonP7QA7
never mind got it to work by holding control while selecting. then go back to manufacture with out moving the model view. edit toolpath your working on. select align to view in tool orientation. and select the freehand curve you created you have to not hold control when connecting the last point to the first point
Bnuno608
Going to try
