Fusion Manufacture
form tool issue
3 REPLIES 3
crunichie
245 Views, 3 Replies
form tool issue
i creating form tools for the mills for a sketch i get to the part. where it is in the tool library when i go to add feed and speeds to the tool the image changes to formless  image preview.
then when i finish enter all the information and accept it highlight orange to say missing info and go back on to the tool all info has gone and re entered and same again
any one else have issue with this all so i am using the update look for the tool library feature if that any help
as it worked before before i start using the new looking tool library
any help be great
thanks
3 REPLIES 3
obrienm
in reply to: crunichie
Hi @crunichie ,
We're aware of these problems related to editing form mill tools in the new tool library. The development team has completed work on a fix, and this will be made available as soon as possible.
In the meantime, I would suggest turning off the Tool Library preview in the preferences dialog if you need to edit a form mill.
Mark O'Brien
Senior Software Engineer
bmiller4BQL
I am having the same issue. How can I resolve this?
seth.madore
in reply to: bmiller4BQL
@bmiller4BQL what issue are you having, exactly? Can you share images and/or a Fusion file that shows the issue?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
