For failed tool imports, does Fusion log errors in a log file?
simspacetn
simspacetn
I have a custom tool management web app. I've written code to export tools from my web app to json so that I can import those tools into Fusion. I'm testing with one tool right now and I'm getting the generic error message seen below when I try to import the json file.
Is there a log file that may offer more details regarding what's wrong with or what is missing in the json file I am trying to import? I'm on MacOS.
I posted this question in the API and Scripts forum but I didn't get any replies. I'm hoping someone in this forum may be able to answer my question.
seth.madore
I don't think there's anywhere where we store them, but it seems sensible that we should. I'll check with the team and let you know!
Seth Madore
simspacetn
Thank for looking it to that @seth.madore!
seth.madore
Could you provide an example of the tool you are trying (and failing) to import?
Seth Madore
simspacetn
@seth.madore, attached is the json file my web app is creating for the import. It is in a compressed/zip file format because the forum would not allow to upload a `.json` file.
I'm sure the json format is wrong and probably missing required data. I'm trying to figure out what is wrong. I found several Fusion log files, but there does not appear to be any errors generated on a failed tool import. I was hoping that Fusion would log what is wrong with the JSON file, but that does not appear to be the case.
Thanks for your help!
seth.madore
So I had one of the developers take a look at your file and the response back was "there's a lot of stuff wrong and/or missing"/
My advice to you is this: In Fusion, create one of each tool type and then export those as a .json file. With that in hand, you can than configure your app to output those same tools and compare the .json for what's missing and/or incorrect.
Seth Madore
