Flow toolpath: Mills both ways (one way selected) due to leads
FrodoLoggins
FrodoLoggins
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Laurens-3DTechDraw
As a tip.
Elaborate a bit on your problem and what you have already tried to fix it.
This will usually get you a lot more responses here on the forum.
What you are seeing here is the combination of the Maximum Stay-down distance, and transition type setting.
If you change the stay-down value to something lower than the distance between the start and end points this will go away. Just as setting the transition type to no contact.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
