Fusion Manufacture
Flow (Preview): Isocurve setting the same but toolpath direction changes
4 REPLIES 4
FrodoLoggins
164 Views, 4 Replies
This past Friday I created a bunch of Flow (Preview) toolpaths and chose the correct Isocurve setting to generate toolpaths like so:
The result is a few stepdowns where each stepdown is horizontal.
This morning some of the toolpaths would generate with the toolpaths milling in the opposite direction like so:
Now all Flow (Preview) toolpaths are like that.
Never changed the "Along U"s to "Along V"s or vice versa but the toolpath directions changed.
The only change I made was changing the stepover value from .01" to .008".
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
4 REPLIES 4
seth.madore
in reply to: FrodoLoggins
Your first (good) Flow(Preview) is set to "V". Your long-time-calculating one is set to "U". Setting it to "V" and changing nothing else gives me this:
Seth Madore
FrodoLoggins
in reply to: seth.madore
Not sure when the save point on that file was.
Friday my toolpaths looked like this:
Yesterday morning (after making no changes to the toolpath's iso direction settings) the toolpaths look like this:
seth.madore
Well, the file you shared was all I have to go on. I'm not sure how it could have gotten into that state where the U/V changed, so we're likely going to need more data points to indicate that there's an issue
Seth Madore
FrodoLoggins
This forum should have a reminder option like Reddit where I can just type "RemindMe! [time] [message]" to send me a reminder email.
