Fusion Manufacture
Flow: Mills same face both ways but "one way" selected
3 REPLIES 3
FrodoLoggins
110 Views, 3 Replies
First milling pass gets conventionally milled the rest of the passes on that face get climb milled:
One way selected:
Not the only face that gets mills both ways either.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
3 REPLIES 3
seth.madore
in reply to: FrodoLoggins
Thread title says "Blend", toolpath says "Flow". I'm going to assume that your fingers decided to type something different than your brain suggested? I think you might be able to edit the title, but I can have a moderator do it if not
Seth Madore
FrodoLoggins
in reply to: seth.madore
Edited title. Yes thanks, this post is about a Flow toolpath.
seth.madore
Thanks for reporting this, I've logged CAM-49514 to investigate.
Seth Madore
