Fusion Manufacture
Flow: Iso direction swapped after opening a radius up
1 REPLY 1
FrodoLoggins
49 Views, 1 Reply
Toolpath used to look like this; all horizontal passes:
Then after using the push/pull tool in the design workspace on this radius:
To make it ~12 thou larger like so:
My toolpath iso direction flipped:
Definitely weird because the U/V curves did not change at all. Below is the edited model [on the left] vs an unedited model. Curves did not change direction:
As you can see the U/V curves did not change but my toolpath did.
This toolpath:
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
1 REPLY 1
FrodoLoggins
in reply to: FrodoLoggins
So in summary: The U/V curves stayed exactly the same (as evident from the second to last image) but Fusion decided to pretend they changed.
I'm hoping in a week when I'm ready to post this program Fusion doesn't decide to stop pretending the U/V curves changed.
