FLOW disrespecting stepover sizes
programming2C78B
programming2C78B
the .03 ID was derived from the .25 toolpath. It's now doing ~.025" stepovers!
Please click "Accept Solution" if what I wrote solved your issue!
Replies (7)
seth.madore
New Flow I assume? Can you replicate this in a sample part and share that here? Or, send me a private message with the A360 link and I'll download it and investigate
Seth Madore
programming2C78B
not that I know of, whatever is packaged in Feb.
seth.madore
Seth Madore
programming2C78B
The file was attached on the previous response.
seth.madore
ah, it's something you can turn on in Optional Features. To answer; you're using New Flow
Seth Madore
jonathanBUCVS
I think I saw similar behavior on a part I was working on in January, and posted here to request help. The toolpath using New Flow and Spiral also did not seem to respond to changes in stepover, unless the stepover was too big, then the toolpath failed. Otherwise changing the stepover didn't seem to significantly alter the number of passes.
seth.madore
Thanks for reporting this and sharing a sample file. I've opened CAM-51633 to investigate the issue.
Seth Madore
