Fusion Manufacture
Flattening Metal Curves for CNC Cutting
1 REPLY 1
davidjzielinski
96 Views, 1 Reply
How do you flatten a compound angle such as a 1" thick by 8" wide steel figure 8 shaped part that is made in one piece?
Does working in sheet metals automatically compensate for radius of the curve or spline stretching like the K factor is set for brake bending? Or is a outside service like ExactFlat need to be used?
Labels (2)
1 REPLY 1
I'm not understanding compound angle...Can you share your file or screen capture?
...and I believe the Exactflat add-in and service may well be abandonware.
