Hey guys,
I mostly have CAD experience in SolidWorks (due to Veterans discount), but my makerspace uses Fusion360 at least for the CAM for their Tormach PCNC1100. I built up a part I want to cut in SW and have imported it into Fusion360 with no issues. I had some problems getting the tool paths to work out what looks to be correct. I watched a lot of videos from NYC CNC to get where I am. I am using a 3/16" HSS flat endmill and a 1/4" ball nose carbide endmill, both uncoated. I realize that these are fairly small tools, but I am not taking that much out. A few pockets, counterbored holes, and some outside filets. The outside filets posed the greatest challenge for me to get the tool paths working decently on. What I was hoping someone could check out is verify my cutting recipe will work and be fairly safe to not break any cutters as money is a bit on the tight side. All the cutters I am using at the makerspace or my personal ones I bought to ease some financials on the makerspace as they are purely volunteer ran on donations with a few monthly subscriptions. Also, the cycle time seems a bit long. It is about 45 minutes for both sides total. I did arrange the tool paths so it is only one tool swap per side. For the WCS and origin for the second side, I used a bottom corner of the part that will be sitting on the parallel, and against the fixed jaw of the vise. This way, I can zero off the back face, side face of the fixed jaw, and the top of the parallel then set the part flush with that face of the jaw.
For actually cutting, I would assume I could cut one side on all 4 identical pieces, switch to the second setup, and cut the final side on all 4 pieces. The holes in the one edge I am not worried about drilling via CNC, I can use the manual Bridgeport for those. They are not near as critical.
Any help here would be greatly appreciated.
Thank you in advance.
Chris
