Finishing pass not generated for 2D Contour
ltomuta
ltomuta
The only difference between these two instances is the finishing stepover. With 0.2 a finishing pass is generated, with 0.1 is not. No warning about dropping it either.
Return to the project minutes later, now 0.1 generates finishing pass, 0.2 does not. What can it be?
seth.madore
Could you capture this in a ScreenCast or share the Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
ltomuta
Hi Seth
Here is the screencast: https://autode.sk/3LtQwJ1
Here is the simplified version of the design: https://a360.co/3vSNS8S
seth.madore
Sorry for the late reply, I did open CAM-36752 to investigate this issue
Seth Madore
