Fusion Manufacture
Finish pass on lathe run from outside
6 REPLIES 6
alexandrubudu
173 Views, 6 Replies
After an inside contour, the finish pass run from od to centrr. How can i inverse?
Video attached
https://youtube.com/shorts/rGKTsBeaivk?feature=share
Thank you.
6 REPLIES 6
seth.madore
in reply to: alexandrubudu
Can you share your file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
alexandrubudu
in reply to: seth.madore
after this, other problem is that the toolpath is crashing the tool. I think the tool is not suitable for the operation, but I can`t find a complete tool metric library for the lathe.
thank you.
seth.madore
Couple of things;
1) On your Profile Finishing, set it to "Back to Front", this will allow it to start at the back and machine out.
2) For it crashing, that's because you've set your "Back" geometry constraint to "Model Back". Set it to "Selection" and select the back wall. Crashing goes away:
Lastly; our generic turning tool library is rather....anemic. Your best solution solution is to create the tools you're using as you need them, saving them to a new library (I prefer using the Cloud Libraries myself, as they are available regardless of what computer I'm logging into)
Seth Madore
Hi Man,
Couple of points.
First, changing to a fixed lead direction will already help out massively with crashing.
Secondly, it's probably good to change your clearance diameter/radius:
And finally when you want run from inside to outside, or actually from the back to front. Find that setting here:
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
thanks for the answer, is working fine now, but I hawe another question. On the threading cycle I have a collision, but I dont see where it is....can youhelp me please? and what is the solution?
@alexandrubudu Simulate the entire setup and the collision will disappear. if you only simulate the threading operation the simulation won't know the material has been removed and will give you false collisions.
Akash Kamoolkar
Software Development Manager
