I'm currently trying to fill in these cast ribs up to the nearest surface. However, I'm struggling to figure out how exactly how to do it. Any help out there would be greatly appreciated.
Solved by HughesTooling. Go to Solution.
You need to figure out the order you need to remove the fillets, then delete the cavities. Then add back any fillets you needed to remove but are still needed. See attached file. Step along the timeline to figure out what I did.
Does this look OK?
Mark Hughes
Owner, Hughes Tooling
Here's another way using sketches and extrusions.
Mark Hughes
