Fusion Manufacture
few issues with the default CL-1 post
4 REPLIES 4
programming2C78B
106 Views, 4 Replies
a) line 210:
homePositionX: {
title : "G53 home position X",
description: "G53 X-axis home position.",
for some reason is being treated as radial, not absolute. We want to go to g53 x-12, so Im having to enter a -6. to get what we expect.
Output:
G53 G0 Z0.
G53 X-12.
b) I cannot find where/how this is also being called up at the end of the operation and for no reason it's missing the g0's. I see that there's one for the initial X retract, but our operator says the machine just crawls back to home with this as it is.
C) can we have a 2nd home position for when Live tooling is used, since they are on the opposite side of the part on this machine?
Please click "Accept Solution" if what I wrote solved your issue!
4 REPLIES 4
Hi line 3974 is where its being output
Its  in Diameter mode because its calling the Xformat
var xFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:2}); // diameter mode & IS SCALING POLAR COORDINATES
Change this line, add the /2 at the end
writeBlock(gFormat.format(53), gMotionModal.format(0), "X" + xFormat.format(getProperty("homePositionX")/2)); // retract
The reason its not outputting G0 is due to using gmotionmodal format which sees the last moves in the Gcode as G0 so Doesn't output it again.
you can add
  gMotionModal.reset();
Before to force the G0 output
Thank you. Youre /2 trick only works at the end of the code though. The first safety retracts are -24  and the safety at end of the program is showing -12.
I'm using the identical
"writeBlock(gFormat.format(53), gMotionModal.format(0), "X" + xFormat.format(getProperty("homePositionX")/2)); // retract" in both places and one is outputting wrong!
The reset didnt work for me. I attached my post. IT SEEMS TO BE BROKEN NOW? I didnt touch line 3987
If you could show me how to get the Visual Studio to show "where" a thing is posted out from, that would be appreciated. I don't know programming languages but have been getting my way around post editing.
EDIT: I found out! There are decent instructions in the pdf. CTRL ALT G !
I fixed it and made some headway. A BIG lesson is you have to SAVE your file before re-posting, otherwise none of the changes will take effect. This made things a lot faster today, since i spent half of yesterday scratching my head why some edits didn't take effect and others did.
You can also do it like I have in the attached. Search for my initials(BD) and you'll see what I did.
xFormat has a scale of 2, zFormat has a scale of 1.
